Printing Rendered Image
sfatelier
Do you mean "Display Camera View"? I can't seem to recall anything called "Display Image from Camera". So your post is a little (okay, a lot) confusing. If I had to take a wild guess I would say that maybe you have some layers that are not aligned and/or rendered, along with a rendered layer??? If so, try "stack layers" and see if that helps. Otherwise post more info and I'm sure someone will come up with a solution for you...
Hello sfatelier:
I would say the most controlled way to output a rendering is to create a viewport. The sheet layer where the viewport resides has a DPI value to control pixel resolution. Choose View->Create Viewport. Then in the Obj Info palette with the viewport selected click Update. After the viewport is rendered it behaves as a bitmap - it won't need to be rerendered during printing.
HTH
