Dexie
How to display Record data attached to polygons
I have just imported some shape files exported from a GIS system. The information comes in three parts -1. Area, 2. contours, 3. anno.
Each of these catagories has - .dbf, prj, sbn, sbx, shp, shp.wml, shx components.
The shape file for 3. anno (annotation) displays lots of single ploygons which represents the position of text for the map eg. road names. In the Object Info pallet under Data there is a record attached to each polygon which includes a field called DescTerm which includes the text that should be located on the appropriate polygon.
eg.
Toid: 1000000969961542
Featcode: 10169
Version: 2
VerDate: 2007-07-27
Theme: Road Tracks and Paths
Change: 2007-07-06 Modified
textangle: 310.0000000000
DescGroup: Road Or Track
DescTerm: Road Name or
make:
PhysLevel: 50
PhysPres:
Text: SOUTHBROOK ROAD
textfont:1
textpos: 4
textheight: 3.00000000000
shape_Leng: 0.00000000000
Is there a routine that will display the correct text eg. (Text: Southbrook Road) from attached records onto the drawing in the location of its polygon from the database file.
Doable as static text, but I don't know of any publicly available, free routines for this. I'm not allowed to post my VectorScript-routines here: it is too annoying to some members, because I claim ?.
Geez ... would you get over it !
Nobody is beating you with a stick... you have the right to put a little ? on anything and everything you so desire.
So Just Do It ...
You may be the most dysfunctional & annoying of all contributors but your knowledge transcends your need for self-flagilation.
Dexie is asking for our advise and assistance ... let's not let that little ? stand in the way of it.. ; )
I don't think the above was in professional and polite tone.
Besides, I've helped as much as I can: I don't know of such a free and publicly available routine; the question was "is there?"
Dixie,
I think some of us who have been doing computer programming for a long time have an idea of how to do this.
But should we give the answer for free? I cannot see a person coding for hours or days without any incentive.
Bill Gates did not become the richest man by giving software for free. When I created the Wallframer script for
MiniCad, which is now Vectorworks, the incentive was not only to make it work but also to profit from it. In my
opinion, the only purpose of free software nowadays is to gain market share.
Luckily for you, I already had created such a script for my own purposes and I do not mind sharing it. But since
I am giving my script for free, the only thing I can come away with is the satisfaction that I helped someone.
For the scipt to work, you will need to do the following:
1. Change the order of the fields so that the name field is at the top (i.e. the top field is "Text"). In the Resource
Browser, look for the record format attached to the polys. Edit the record and move the "Text" field to the top.
2. In the Vectorscript Plug-in Editor, create a new tool and give it a name. Click on the script button and paste
the following:
PROCEDURE LabelShape;
{Debug}
CONST
kFLDNO = 1;
kTHICK = 20;
kHGLIT = 7; {Highlight color = Red}
kTEXT = 10;
TYPE
U_Pt2D = STRUCTURE
x: REAL;
y: REAL;
END;
VAR
classColor,classThick: BOOLEAN;
thick: INTEGER;
colorR,colorG,colorB: LONGINT;
hglitR,hglitG,hglitB: LONGINT;
prvLabel,curLabel: STRING;
labelVec: VECTOR;
prvShapeHdl,curShapeHdl,labelHdl: HANDLE;
mouse,tmp,pt1,pt2: U_Pt2D;
FUNCTION GetlabelField(objHdl: HANDLE; VAR fieldVal: STRING): BOOLEAN;
VAR
result: BOOLEAN;
rec: HANDLE;
recName,fldName: STRING;
BEGIN
result:= FALSE;
IF NumRecords(objHdl) > 0 THEN
BEGIN
rec:= GetRecord(objHdl,1);
recName:= GetName(rec);
fldName:= GetFldName(rec,kFLDNO);
fieldVal:= GetRField(objHdl,recName,fldName);
IF Len(fieldVal) > 0 THEN
result:= TRUE;
END
ELSE
fieldVal:= 'No Record';
GetlabelField:= result;
END;
BEGIN
PushAttrs;
TextJust(2);
TextVerticalAlign(5);
prvShapeHdl:= NIL;
labelHdl:= NIL;
prvLabel:= '';
ColorIndexToRGB(kHGLIT,hglitR,hglitG,hglitB);
GetMouse(tmp.x,tmp.y);
Repeat
GetMouse(pt1.x,pt1.y);
IF labelHdl <> NIL THEN
HMoveBackward(labelHdl,TRUE);
curShapeHdl:= PickObject(pt1.x,pt1.y);
IF curShapeHdl <> NIL THEN
IF GetType(curShapeHdl) = kTEXT THEN
curShapeHdl:= NIL;
HMoveForward(labelHdl,TRUE);
IF curShapeHdl = NIL THEN
BEGIN
SetCursor(arrowC);
curLabel:= 'No Object';
IF prvShapeHdl <> NIL THEN
BEGIN
IF classColor THEN
SetPenColorByClass(prvShapeHdl)
ELSE
SetPenFore(prvShapeHdl,colorR,colorG,colorB);
IF classThick THEN
SetLWByClass(prvShapeHdl)
ELSE
SetLW(prvShapeHdl,thick);
prvShapeHdl:= NIL;
Redraw;
END;
BEGIN
DelObject(labelHdl);
labelHdl:= NIL;
Redraw;
END;
END
ELSE
BEGIN
NameClass(GetClass(curShapeHdl));
IF curShapeHdl = prvShapeHdl THEN
BEGIN
IF NOT GetlabelField(curShapeHdl,curLabel) THEN
BEGIN
IF Len(curLabel) = 0 THEN
curLabel:= 'No Data';
END;
IF (tmp.x <> pt1.x) | (tmp.y <> pt1.y) THEN
BEGIN
SetCursor(smCrossC);
TextOrigin(pt1.x,pt1.y);
BeginText;
curLabel
EndText;
labelHdl:= LNewObj;
SetFPat(LNewObj,0);
tmp:= pt1;
Redraw;
END;
END
ELSE
BEGIN
BEGIN
IF classColor THEN
ELSE
IF classThick THEN
ELSE
END;
classColor:= IsPenColorByClass(curShapeHdl);
IF NOT classColor THEN
GetPenFore(curShapeHdl,colorR,colorG,colorB);
SetPenFore(curShapeHdl,hglitR,hglitG,hglitB);
classThick:= IsLWByClass(curShapeHdl);
IF NOT classThick THEN
thick:= GetLW(curShapeHdl);
SetLW(curShapeHdl,kTHICK);
BEGIN
END;
prvLabel:= curLabel;
prvShapeHdl:= curShapeHdl;
BeginText;
curLabel
EndText;
labelHdl:= LNewObj;
SetFPat(LNewObj,0);
tmp:= pt1;
Redraw;
END;
END;
Until Mousedown(mouse.x,mouse.y);
IF (curLabel = 'No Record') | (curLabel = 'No Data') THEN
BEGIN
IF classColor THEN
SetPenColorByClass(curShapeHdl)
ELSE
SetPenFore(curShapeHdl,colorR,colorG,colorB);
IF classThick THEN
SetLWByClass(curShapeHdl)
ELSE
SetLW(curShapeHdl,thick);
curShapeHdl:= NIL;
BEGIN
labelHdl:= NIL;
Redraw;
END;
END;
BEGIN
tmp:= pt1;
Repeat
GetMouse(pt2.x,pt2.y);
IF (tmp.x <> pt2.x) | (tmp.y <> pt2.y) THEN
BEGIN
labelVec[1]:= pt2.x - pt1.x;
labelVec[2]:= pt2.y - pt1.y;
TextRotate(Vec2Ang(labelVec));
BeginText;
curLabel
EndText;
labelHdl:= LNewObj;
SetFPat(LNewObj,0);
tmp:= pt2;
Redraw;
END;
Until MouseDown(mouse.x,mouse.y);
IF classColor THEN
ELSE
IF classThick THEN
ELSE
SetDSelect(labelHdl);
END;
PopAttrs;
END;
Run(LabelShape);
3. Click OK to accept the script.
4. Add the tool that was created to your workspace. If you did not assigned it to a group, it will be under
Miscellaneous.
5. After selecting the tool, the first click will activate the script, If you are over the polygon, the value of the first
field will appear. If you click in an open space, the string "No Record" will appear. During this time, you can
move the mouse around and it will pick up the name as you get closer to a polygon.
6. Click again to set the center of the string. After clicking, the string will stay in its place. If you move the
mouse to the left and in a circular motion, you will see the string move around its center. If you double click
instead of a single click, the angle of the string will be zero, which means it will stay horizontal.
7. Click again to set the angle of the string.
Repeat steps 5 to 7 until you finish labeling all the streets.
Another solution to this, of course, would be to reverse-engineer what Esri does to label all the polygons at
once. This was something I was not willing to spend the time doing.
Enjoy!
I forgot to mention that the text will be displayed with the document default attributes. So before running the script click on an open space and set the default text font, size and style you want the field value to display.
Sorry to take so long in replying. I have been on holiday for a week or so. Thanks very much for the reply and I will give it a try and would like to thank you in advance for your generous help.
