don Posted January 26, 2000 Share Posted January 26, 2000 How do I enter survey points by hand using Vector Works 8.5.1. Northing,Easting, Elevation so that I can later create contours using the DTM feature. [This message has been edited by don (edited 01-27-2000).] Quote Link to comment
Guest Posted January 27, 2000 Share Posted January 27, 2000 To enter information to be calculated for DTM you can use the "3D Locus" tool to place points on the screen. Once you place the 3D locus you can then give them a height by going to the object info palette and entering a Z value. Or you can use 2D polygons and draw the contours in 2D and then use the "2D polys to 3D contours" command that is located in the DTM menu. Quote Link to comment
