Plot Files
kspencer
Export your files as PDF, but check with your printer first to make sure that they can print from PDF. Most will be happy yo print from PDF.
File > Export > Export PDF (Batch)...
This works really well and allows you to choose the sheet layers that you want to export. It also lets you choose if you want to print the drawings in colour or black and white
If you really need to make a plot file, that's a system operation. On Windows, install the printer that's going to be used - just as if you had the printer plugged in. Then when you print, check the box labelled "Print to file".
I've been told you can't do that on MacOS.
