carpalmer Posted March 20, 2007 Share Posted March 20, 2007 imported a file from ACAD and I'm getting several dashed lines in the X and Y going off to infinity...! any ideas? Thx, Carpalmer Quote Link to comment
BG Posted March 20, 2007 Share Posted March 20, 2007 Turn off "snap to Loci" in Vectorworks preferences. BG Quote Link to comment
carpalmer Posted March 20, 2007 Author Share Posted March 20, 2007 wow, you're fast BG. It worked... Thanks so much. Carpalmer Quote Link to comment
David Ormsby Posted March 22, 2007 Share Posted March 22, 2007 Also - you can turn these off at import, should you like using your own Loci. In the DWG Import window click Use Custom under Import Options. Click Set Custom Options, go to the Objects Tab and check Symbols under Import Points As. Quote Link to comment
