Multiple File Batch Render / Output?!
mark_at_custom
Hello all!
Does anybody know anything about a batch render / export function that'll allow for viewports to render and output across several files in a que?
I see this issue in a related post. Hopefully with this question being restated / repeated we can get a little more traction.
Other CAD packages allow for multiple files to render / print from a que without having to manually open, update and output each viewport or view or whatever in each file.
Thanks!
1 answer to this question
In case anybody else comes across this. Another user from a similar post suggested using "Workgroup reference" to bring in the design layers from the differing mcd files and make viewports [on sheet layers] from their layer links. This allows for the pdf batch export or batch print function to do their thing.
