milon Posted March 14, 2007 Share Posted March 14, 2007 can anybody tell me, why some simple files 12.5 makes hour to print on a designjet 755cm (latest driver), instead few second on 11.5? actually i work on 12.5 and print on 11.5, it's boring... thanks for your post. m. Quote Link to comment
0 Christiaan Posted March 14, 2007 Share Posted March 14, 2007 Are you using the same paper and resolution settings in the printer dialogue? Quote Link to comment
0 milon Posted March 14, 2007 Author Share Posted March 14, 2007 yes...unfortunately 600 dpi printer, 300 dpi document file, scatter, paper etc...same. something else get wrong... thanks m. Quote Link to comment
0 milon Posted March 15, 2007 Author Share Posted March 15, 2007 Ok! ok! after hours of hard work, i find it! it's the quartz imaging in VW prefs! don't put ever a cross into this tool. thanks everybody m. Quote Link to comment
0 ionw Posted March 15, 2007 Share Posted March 15, 2007 The only issue that you will find, is that then everything will be drawn with a square pen, and your diagonal lines will be thicker that your orthagonal lines. Also this seems to be a HP only thing, because printing to our Oce or Ricoh is nearly immediate, while the same print to our HP 5000 or 800PS takes forever. Also if you happen to use it, turning off Quartz imaging makes Layer opacity unavailable. Quote Link to comment
milon
m.
4 answers to this question
