Object Info data changing
After picking more than one object with different widths to each other and changing data in the 'Object Info' box on the line above the width data and pressing enter may change the widths on the next line to the same aswell.
(This is just an example and may happen to any fields above each other)
How can I change one set of data and not the other without picking each object separately ?
webforge@highway1.com.au
What version of the software are you using Trevor. The was a problem with setting attributes I have not heard of this with The Object info.
Shawn Waithe
Diehl Graphsoft inc.
Tech Support Manager
