texture resolution
welshpe
I am using the renderworks textures that shipped with VW. I don't have a layer DPI. I reset the resolution in the document preferences for raster printing to 150dpi. Helped a little but screwed up the lighting. Maybe I need to get a handle on the lighting first?
Welshape, you adjust the DPI of EACH SHEET LAYER by going into the LAYER setup and then changing the number. The default of 72dpi is fine for on-screen viewing, but when it comes time to print final sheets I usually increase to 300dpi. Be aware that increasing the dpi will increase rendering (VP Updating) times accordingly.
