Michael_Eschenbach Posted March 1, 2007 Share Posted March 1, 2007 I open a brand new document.... 1 layer only. I draw 4 walls on this standard design layer....ie 8" block wall, 40' long & 8' high throughout. I create a worksheet to get the data from that wall and use the average wall height function "=WALLAVERAGEHEIGHT", to obtain the wall height. I set the layer function to the correct layer, set the type function to "wall".....and I come up with varying wall heights from 9' 3/8" to 9' 5/8"... where is the problem that is creating the erroneous data? Quote Link to comment
Petri Posted March 1, 2007 Share Posted March 1, 2007 I wish I knew. The same happens when querying a wall with VectorScript. Now, of course the entire concept of "average wall height" is curious. What does it mean? If I have a wall of x metres in length (say 10), y square metres in area (say 100), but heights varying between 0,001 and 100 metres, what is "average"? Quote Link to comment
Michael_Eschenbach Posted March 1, 2007 Author Share Posted March 1, 2007 I think "average wall height" comes from an individual wall with a gable pitch in the center. for that the function might be ok..... but the walls I am describing are only one height end to end. Quote Link to comment
Petri Posted March 1, 2007 Share Posted March 1, 2007 Uh-huh. The average height reported is not right even then... Quote Link to comment
panthony Posted March 1, 2007 Share Posted March 1, 2007 This is a known bug. VW has a problem with this...they have really got the math screwed up in relation to walls. Programmer probably had a severe hangover when the code was written to the extent that he could not remember where he put it. Maybe they should look under the sofa cushions. Pete A Quote Link to comment
blimey Posted May 23, 2007 Share Posted May 23, 2007 Does anybody knows whether this bug might soon be fixed? or which previous version could be reinstalled that didn't yet have that problem? Quote Link to comment
islandmon Posted May 24, 2007 Share Posted May 24, 2007 According to the inside sources at NNA this is NOT a bug issue, cus as everyone knows the average height of the wall depends on the average height of the person looking at the wall. Therefore, you will need to add or subtract your height from the result ; ) Quote Link to comment
blimey Posted May 24, 2007 Share Posted May 24, 2007 Hi Islandmon! :-) Well in fact, this is quite a serious issue to me! I spent some time back a few monthes ago preparing my worksheets (tons of them for the scheudule of a huge project (for my standard of course?, knowing that I would need them to be very efficient today. Then we upgraded to VW12.5. I didn't pay attention about the worksheet for a while, I was more preoccupied by the conception (and I thought I had good functionning worksheets to rely on). I just got strucked by the awfull!!! reality two days ago, I couldn't believe it was a bug!!! now I've got my deadline in 10 days... does any one tried something that worked to solve the issue? Or did anyone tried to reinstall VW12 and run the worksheets on drawing made in VW12.5??? Quote Link to comment
Vectorworks, Inc Employee Robert Anderson Posted May 24, 2007 Vectorworks, Inc Employee Share Posted May 24, 2007 Look for this bug to be fixed in an upcoming maintenance release. Quote Link to comment
blimey Posted May 24, 2007 Share Posted May 24, 2007 thank you robert, is there a special area where the maintenanse release are posted? Do you have an idea about how soon that can be? Would you have any tip for me in the meantime? How do you think drawings made in VW12.5.1 would react if put back in the VW12 version? would that work? Quote Link to comment
Dieter @ DWorks Posted May 25, 2007 Share Posted May 25, 2007 Why not just use the wall height if you know that there are no peaks??? Quote Link to comment
blimey Posted May 30, 2007 Share Posted May 30, 2007 I have slope but I can use average height, the big problem is the area, it ws nice to have all the windows and doors deducted, now I have to count the symbol and sustract;.. anyway too late for me too find a solution, will do it the old way: this means manually. best Quote Link to comment
Dieter @ DWorks Posted May 30, 2007 Share Posted May 30, 2007 (edited) you need to have the surface area??? there is a command for this! Edited May 30, 2007 by someonenamedlink Quote Link to comment
