'sides' on a DTM
Step 1: Generate a Digital Terrain Model with the hull check box selected.
Step 2: Create a new layer and move the DTM hull to this layer and convert it to 3D Polygons.(note use the convert to 3D polys command found under the model menu)
Step 3: Use the 3D polys to 3D loci command under the DTM pull down menu and select the checkbox delete 3D polys.
Step 4: Copy 3D loci and perform a paste in place on the 3D DTM layer.
Step 5: Then perform the command float 3D objects.
Step 6: Repeat the paste in place command again.
Step 7: Place the DTM in a 3D view and use the 3D polygon tool to draw the skirt of the DTM by connecting the 3D loci points.
[This message has been edited by Shawn (edited 01-18-2000).]
