Clipping Work Group References
Is there a command to clip a Work Group Reference in a design layer, similar to AutoCAD's Xclip? On sheet layers we successfully use viewports, but is there a command for clipping the referenced drawing in the design layers? Our referenced design layers typically contain collections of old designs and variations and when we WGR them in, we'd like to clip the view to just the relevant drawing so that the referenced drawing doesn't sprawl across the screen. How do you create the equivalent of viewports for design layers?
No such thing. For your old designs and variations, specific layers would be be most efficient method (I assume you use classes to separate objects' "what"). Sending or copy/pasting these to such layers would also enable you to quickly revisit them in proper context (ie. the correct location).
