Ericoxer Posted February 17, 2007 Share Posted February 17, 2007 Up until now, I've really only had to render rosco gel. I've recently had to render some Apollo and Lee gel, and havent had any luck. Is there a file that i can edit, or somewhere where i can enter these colors? Quote Link to comment
ghunter64 Posted April 22, 2007 Share Posted April 22, 2007 There is a file in /Applications/Vectorworks 12.5.1/Plug-Ins/VW_Spotlight/Data/Lee Colors.txt which contains the color mapping info for Lee filters. It appears to be quite out of date. The mapping info for other filters e.g. Rosco and GAM also reside in the same directory. If you open the file (in TextEdit) you can see which colors are are supported. For colors that aren't in the file(s), VW just seems to use white. Hope this helps. Quote Link to comment
