Dave Barnes Posted April 14, 2006 Share Posted April 14, 2006 I'm using VW11.5 Spotlight and having a problem with names in the Intrumentation key... The instruments all show up, but several have the same names. I tried to go to the symbol area and rename, but to no avail. What did I do wrong? thanks. Dave Quote Link to comment
Mickey Posted April 17, 2006 Share Posted April 17, 2006 I don't know why it's doing that, but you can edit the key directly. It's a group so just right click on it and you can change everything. Quote Link to comment
Dave Barnes Posted April 18, 2006 Author Share Posted April 18, 2006 Thanks... ya, I did that. And it does fix it the small side of the problem. Wonder if there's a reason for the larger problem? Quote Link to comment
rando Posted July 7, 2006 Share Posted July 7, 2006 I see this is an old thread but... I have been having key problems w/ VW12 on a PC (WinXP). When the key is added, the enclosing box is drawn too small so some of the text is not enclosed. Also the instruments seem to appear in a non-ideal order. I would like to be able to specify either the order or even better just tell VW to group instruments of similar type (fresnel, ERS, etc.) I don't know how VW decides the ordering--is this settable somewhere? Of course I can fix the bounding box size and order issues manually but then can't let VW build the key again. Is there a fix? Quote Link to comment
