Stacy Posted February 8, 2007 Share Posted February 8, 2007 (edited) When rendering an image with unshaded polygon option in a viewport some of the wall lines and roof lines from the opposite side of the view show through. Like showing a view of the front of the house walls from the back view of the house will show through.Why is this? Do you need to have Renderworks for the drawings to render properly? Edited February 8, 2007 by Stacy Quote Link to comment
P Retondo Posted February 8, 2007 Share Posted February 8, 2007 It might be a bug - I haven't used that rendering mode for years. Try looking at it with OpenGL rendering (generally faster and better than the polygon renderers, but it is shaded). If you still see things from the back, maybe some of your objects aren't filled. Quote Link to comment
Guest Posted February 8, 2007 Share Posted February 8, 2007 Send the file along w/ a description of the problem to bugsubmit@nemetschek.net - it's likely a bug. Quote Link to comment
