Demolition tool
Francois Levy
I often have to manually clip objects and reasssign them to other classes in as-built drawings/models in order to generate demolition plans. Wouldn't it be grand if there were a Demolition Tool? for starters, anything within a drawn poly could be clipped and assigned to (a) user-defined demolition class(es). The tool's Preferences box could list all current file classes and how they would map to demolition class(es), such that a door in a wall would map to a different demolition class (with different graphic attributes) than the wall itself.
1 answer to this question
Twas thinkin' more along the lines of a sweet bit of code that when activated
would demolish an entire project... class by class, Layer by Layer, Symbol by Symbol ...
with screaming & wailing female sound effects ...
intense visuals and puffs of smoke as the polys burn...
segment by segment...
Purge on steroids...
for those rare moments when a damaged psych could really use complete file compaction ...
