Type changing on Refresh
I've run into some wierdness - running 12.51 Spotlight and using the Field Template symbols.
After importing from Lightwright, and refreshing all instruments, the Inst Type field is changing to "Light" for all fixtures, rather than (for example) Source 4 19. Before refreshing, the data shows correctly in the OIP. After Refreshing, all other data is fine except for the Inst Type field.
I tried replacing the Field Template symbol with the SL version and the Inst Type shows correctly. I've double checked the Record data is correct in both. I've used the Field teplate symbols for quite a while without this problem, but it's the first plot with 12.5.1.
Any Ideas?
Thanks
