Record Format Quirk
I have a symbol with some text linked to a record format...In the record format edit pane it clearly states that there is a default value for that particular field name. However, when I link text to that field, it disappears instead of giving me the default value. And when I insert the symbol and go into the object info pane to edit the text, in that field name, there is no default. Is there a limit to the number of field names with default values you can have in a record format? I have 87 fields in this particular record format. I'm using VW 12.5.1 on an Intel Mac Mini. OS 10.4.8 Thanks.
Jim
