"Basic" file operation
Jorgeusa
Help - This seems to be a very simple task ... but I have not been able to figure this out by myself confused.gif
I'm trying to "force" vectorworks 12.5 to open/import dxf files automatically in a script ...but at this point, I can not even open a specific file in VectorScript - What's the command to open a specific file with VectorScript ?? .
Realizing that there is no way to open dxf direct, the idea was to:
A) open a new (empty) file
B) force VectorWorks to import a spcified dxf file automatically into the newly created file / window...
Any Ideas ????
Is there any way of starting a "batch" conversion dxf to VW drawing automatically without user intervetion ??
The issue is not to keep the file name ... I just need to be able to automatically open the (dxf) file out of Filemaker to be able to look at it...
Therfore Copying the file into temp folder (Apple script)- converting it with temp name (VW) - open as VW drawing with temp name would work just fine (Apple Script) ... wink.gif
Yes ...
VW will open both '.dxf' and '.dwg' natively. Therefore, using Applescript "open" with VW , then
close v : close an object
close reference : The object to close
[saving yes/no/ask] : specifies whether or not changes should be saved before closing
[saving in alias] : the file in which to save the object
___
DoScript v : Execute a MiniPascal command. Any command that can be executed from the command palette can be sent as a script.
DoScript anything : The script to execute
Maybee you can jump start me here
I did try the following Appple script
tell application "VectorWorks"
activate
select file "FilePath"
open selection
end tell
where Filepath = "Kohler:CadDrawings:Drawings:5500:100-5542.dxf"
this returns the following "apple script error"
VextorWorks got an Error: file
doesn?t understand the select message.
