Egilson1 Posted February 15, 2006 Share Posted February 15, 2006 So I have been playing with the drape tool and trying to apply a texture to it to create a star drop. I downloaded a texture, but when I apply it I only get a black field and a few wierd lines instead of a black field with white dots. Any thoughts what I might be doing wrong. Running Spotlight 12 on Win XP. Thanks [ 02-15-2006, 03:38 PM: Message edited by: Egilson1 ] Quote Link to comment
Hunter B Posted February 17, 2006 Share Posted February 17, 2006 I just tried to do the same thing. I had to change each drape to a nurbs surface and then map the texture to the surface. Quote Link to comment
Vectorworks, Inc Employee klinzey Posted February 17, 2006 Vectorworks, Inc Employee Share Posted February 17, 2006 The drapes are numbs surfaces. You may need to adjust the attributes of the source texture. If all else fails, you can ungroup the drape and apply the texture directly to the nurbs surface. Kevin Quote Link to comment
Egilson1 Posted February 21, 2006 Author Share Posted February 21, 2006 Well, I figured out my issue. I had the drape "flat" as in no fullness. Once I changed that it worked fine. Quote Link to comment
