Viewport editing
When I edit the crop or annotation of a viewport there is a button at the top right of the window which takes me back to the sheet layer view. There is not a button when I edit the design layer so I have to go back via the layers button on the drawing header. It would be great if there was a button for this. Am I missing one or does it not exist? (VW12.5.1 on MacOS10.8 on Intel Mac Pro with 2Gb memory)
If your talking about having jumped to a design layer from the viewport it represents, there is a button(s) you can use to jump back to the sheet layer from whence you came. It's on the lower left represented by two triangles in the scroll bar display which has to be turned on in the preference options. It's the previous view(s) function and I believe you can set how many are stored in memory.
