welshpe Posted January 9, 2007 Share Posted January 9, 2007 How do you create a dormer(?) that is in the plane of the wall that the roof sets on without having the eave carry thru? Quote Link to comment
Don@Black Dog Posted January 9, 2007 Share Posted January 9, 2007 Do a search for Dormers or Roofs and you will find a ton of stuff. VW has a basic and simple dormer tool for single window dormers that are a bit tough to modify, but ok. Or build them manually with walls, a roof rectangle, roof faces,cut out the hole, etc. Quote Link to comment
CipesDesign Posted January 9, 2007 Share Posted January 9, 2007 Dormers are sort of strange in VW's. The recommended work flow calls for the insertion of a window symbol into a roof to initiate the process. I usually just create my own walls/roofs as needed (because it seems to give me more control). Quote Link to comment
