Jason Turley
VectorWorks 12.5.1 is available on version tracker
David, 12.5.1 is a maintanence release and is free of charge for licensed owners of 12.0.0 and 12.5.0.
I understand, but I have to call in and order it since I only have a dial-up connection. On the plus side, I've had only good luck with the upgrades on CD.
A lot of the Powerbook G4s have wireless, as do a lot of libraries (not to mention Starbucks, McDonalds, and others.) If you want to speed up the process over calling and mailing, perhaps a little quality reading time is in order.
I drove over to the county library with my powerbook and downloaded rel. 12.5.1. It stalled three times while downloading, and I had to "stop" and "resume" each time. A bit unnerving. The download took about 30 minutes.
Afterward, the software installation went smoothly, and there doesn't seem to be any problem with its operation.
Having looked at the 3 to 4 improvements is it worth the hassle to upgrade from 12.5 to 12.5.1?
How many wish list items registered on this board have been incorporated?
As a UK user will the upgrade overwrite by 12.5 uk version?
Is there a UK version?
I made a backup copy of my 12.5.0 directory before upgrading to 12.5.1. Eventually, I'll erase the earlier version if there are no problems.
I don't know whether this is possible for a non-U.S. version.
Another update and still they can not fix the DXF/DWG import command bug when the original files are in UTM coordinates
VW 12.51 still insists in setting to 0,0 the origin of the center of the imported DXF/DWG files no matter what options are selected by the user (default, custom)
Come on make VW a real world CAD software!! No georeferencing or datum coordinates support this is unexcusable! mad.gif
Is there a problem when you select in DXF DWG Import Options the "Use World Origin Instead of User Origin" button?
I am back and till no answer from NNA on my posting some 5 months ago:
Wish list items are typically included in major releases. Minor releases are typically limited to issue resolutions.
This is a general industry standard for software.
Contact Computers Unlimited, as usual, for localization questions/concerns.
It should be fine, but nonetheless, a tech support question like this should be geared towards them.
