Tobias Posted January 6, 2007 Share Posted January 6, 2007 I have a VW 12.5 file that when I use the "Set Sun Position..." Dialog under View>Lighting it opens with the Lat/ Lon values with long numerical values that don't relate to degrees and minutes. If I try to change the values to the site location (or any other value I get an error that says "The minute value is bad or out of range" and I am unable to change the Lat/Lon values. I have tried other files and they work as expected. Unfortunately the back ups of this particular file all exhibit the same problem. Is there a way to purge the Lat/Lon value in the file? Where is that info located? I have also tried removing and re-adding the "Set Sun Position.." command from the workspace, and the "reset plugins" command, both with no effect. Quote Link to comment
