Bruce Glaser Posted January 5, 2007 Share Posted January 5, 2007 I added Option-Command-8 as a key equiv for this and it doesn't work. The VIEW menu blinks as if its happening, but the command does not take. I've tried this on 3 different Macs all using 12.5. Any ideas? Quote Link to comment
Guest Posted January 6, 2007 Share Posted January 6, 2007 (edited) Try to delete the menu from the workspace using the Workspace Editor. Then, add it back and re-assign the shortcut. Check to make sure this isn't reserved by something important in the OS, too. Edited January 6, 2007 by Katie Quote Link to comment
Bruce Glaser Posted January 6, 2007 Author Share Posted January 6, 2007 Thanks Katie, I'll try that. Quote Link to comment
Bruce Glaser Posted January 8, 2007 Author Share Posted January 8, 2007 Katie It didn't work. I get no message saying the combination is being used by another command either. I tried Shift-Command - 8 and that worked. Unless you can figure out why Option-Command-8 won't work, I'll keep using it. Bruce Quote Link to comment
Guest Posted January 8, 2007 Share Posted January 8, 2007 The only thing I can think of is that the combination is reserved by some other operation in the operating system. Quote Link to comment
Bruce Glaser Posted January 9, 2007 Author Share Posted January 9, 2007 I checked the OS and Option-Command-8 turns on ZOOM. I never would have noticed this because all the settings for ZOOM are at their minimized levels in the preference pane so I never noticed an action taking place when I tried to use the key combo. At least there's an explanation. Quote Link to comment
