Undo Bug
Jim T
When undoing several steps, my light units at some point will take on the characteristics of the Label Legend screen. A rectangle surrounds the light and all of the information appears as if some sort of spread sheet.
The only way to get rid of it is to "Command Y" and then fix the problem in a way other than undo,
Anyone have this happen??
Yes, it's a bug and will be fixed in the next release. (Don't even bother to ask when that is; I can't tell you.) It will fix itself if you change a parameter or run the Refresh Instruments command.
[ 01-22-2006, 07:16 PM: Message edited by: klinzey ]
