jerry-built Posted December 14, 2006 Share Posted December 14, 2006 I import AutoCad drawings from a surveyor. He draws hedges as polylines with a user defined line type which is not linear. This line has a straight section then slopes up and down again to form an inverted "V" and carries on straight again. When you apply this to a polyline it looks good as a hedge. VW 12.5 does not seem to be able to import the line, which just comes in as a dashed line. Is there a way to import this? Quote Link to comment
Guest Posted December 14, 2006 Share Posted December 14, 2006 Send the file along with a description of the problem to tech@nemetschek.net Quote Link to comment
jerry-built Posted December 15, 2006 Author Share Posted December 15, 2006 Thanks for your reply, Katie. I have done this. Quote Link to comment
