sfatelier Posted December 14, 2006 Share Posted December 14, 2006 I'm trying to render an extuded polygon but all I get is a wire image. When I produce an extruded cylinder, it renders just fine. Why is one rendering and the other not? Thanks! Quote Link to comment
Ray Libby Posted December 14, 2006 Share Posted December 14, 2006 Does it have a solid fill? Quote Link to comment
Guest Posted December 14, 2006 Share Posted December 14, 2006 Another thing to check is to see if the object is on the active layer. When rendering, only the active layer renders, unless you are using Stack Layers. A good way around this is to either use Stack Layers or create a Layer Link. Quote Link to comment
sfatelier Posted December 15, 2006 Author Share Posted December 15, 2006 Thanks, I'll try that. Quote Link to comment
