grahamc Posted December 13, 2006 Share Posted December 13, 2006 Does anyone know a way for several people to use the same templates (.sta files)? Ie. can I make the default location for templates a server somewhere? Or is the only way to copy the .sta files into each individual user's 'Templates' folder? Thanks,Graham Quote Link to comment
Grant M Posted December 14, 2006 Share Posted December 14, 2006 Yes you can store templates on a server. I put the stationary files in a folder called templates on the server and then copy an alias (shortcut) to the vectorworks folder on individual workstations. Quote Link to comment
grahamc Posted January 11, 2007 Author Share Posted January 11, 2007 Hi Grant Thanks. I've tried over and over but I can't get this to work. I create the 'Templates' folder on the server, make an alias, then move the alias into my Vectorworks folder. Every time this is done, the 'New...' command just opens a blank document without the stationary option. I've tried renaming the alias to 'Templates' and 'Templates Alias' but it never works. A blank document opens every time unless a real local Templates folder is there. Am I doing something wrong? Cheers, Graham Quote Link to comment
Guest Posted January 11, 2007 Share Posted January 11, 2007 You need to have at least one template file in the templates folder on the local computer in order for it to recognize there are templates. An alias or shortcut doesn't cut it. Once a template file exists, the alias can be read by the program. Quote Link to comment
Grant M Posted January 16, 2007 Share Posted January 16, 2007 Graham, yes the alias needs to be named templates as per the folder it replaces. The server also needs to be mounted before launching Vectorworks. I have had no problems without having another template file on the local computer, contrary to what Katie says. However I do use one anyway (in the VW application folder - called Vectorworks default) so that VW always opens a metric drawing when launching. hth cheers grant Quote Link to comment
Christiaan Posted January 16, 2007 Share Posted January 16, 2007 We used to do it over the network like this but we've found a much more robust method is to use a program like Apple Remote Desktop to propagate the files to each machine. One machine is used as the master (for templates and the symbol library) and then we use ARD to upload these files to all the other machines whenever they're updated. Quote Link to comment
Guest Posted January 16, 2007 Share Posted January 16, 2007 Some installations do not install a Templates folder - which causes confusion for some users. Quote Link to comment
