Batch print not using correct paper size 12.5
Mickey
Like the title says when doing a batch print of several sheets the paper size defaults to the largest, in our case E. We are using a HP Design Jet 500. Each Sheet is set with a printable area of "one printer page" and the printer set-up is set to "Arch D" yet when we batch print they all come out in E size.
If I print each sheet individually they print on the correct size. This worked fine in previous versions of VW.
Anyone have any ideas why this is happening?
4 answers to this question
So when is it not working? (I'm confused)
When I print to my plotter using batch print.
We have a HP Design Jet 500. Printing individual sheets prints correctly. When using batch print each sheet prints in E size regardless of printer settings in the drawing.
This is happening on two different computers with two different files. One computer uses Windows XP the other uses W2k.
