Sandking Posted December 11, 2006 Share Posted December 11, 2006 Ok, so I've set 3d view and it looks ok. I then create viewport from it and on sheet layer it looks like it's out of the crop (I can see only small elements on the edges) and it looks like it changed from perspective to isometric view. Any hint on that? Quote Link to comment
Guest Posted December 11, 2006 Share Posted December 11, 2006 (edited) Select the viewport and check out the View settings in the Obj Info Palette. If the settings are set to Iso, change it to perspective. You can also edit the viewport and go into the crop mode to reposition the crop OR use the Translate View tool to pan the drawing into place (inside the crop) You can also use the flyover and walkthru tools while in this edit mode to get the view you are looking for. With that said, however, you have the view in the Design Layer when you create the viewport is what should stick, unless you somehow change it in one of the dialogs. Edited December 11, 2006 by Katie Quote Link to comment
Sandking Posted December 12, 2006 Author Share Posted December 12, 2006 Thanks a lot... again! Quote Link to comment
