Ken Bowen Posted November 26, 2006 Share Posted November 26, 2006 Can I get guidance on using VW to draw boat hull "Lines?" I noticed when I registered V12.5 there was a check box for people using the software for this, but so far I have not found reference to this use in the manual or in a search of the site. Ken Quote Link to comment
islandmon Posted November 27, 2006 Share Posted November 27, 2006 Modeling Hulls is a peculiar problem. The easiest approach is to use Lofting of the Cross & Longitudinal sections keeping the vertex count consistent. Adding & Subtracting Solids completes the shape. However, describing the exact hull polyline curvatures may require the use of a dedicated 2d Plot app or Excel then exporting the xyz data for parametric curves. Quote Link to comment
Guest Posted November 27, 2006 Share Posted November 27, 2006 You can also create the boat sections using a NURBS curve, then use the Create Surface from Curves command to create a hull from the nurbs curves. This is how exotic cars are also designed in VW. Quote Link to comment
Kurt Magness Posted November 28, 2006 Share Posted November 28, 2006 Solidworks has a tutorial on their web site that shows the basic concepts of boat hull design. Perhaps you can look at it and get an idea of how it works then translate it to vwks tools. Basically nurb curves and lofting are what you want to do. Although its a little tricky to manipulate them. Once you get the hang of it it goes pretty smoothly. http://www.solidworks.com/pages/products/SolidWorks_2007/SolidWorksOfficePremium2007.html Quote Link to comment
Kaare Baekgaard Posted November 29, 2006 Share Posted November 29, 2006 I have done this with a sailing dinghy. Make an extrude of a bezier curve with no more control points than required - coarsely representing one half of the midsection of the hull. Convert it to a nurbs surface (it should become a single surface). Work on the nurbs points of that surface individually to shape the hull. You can also work with the weight of the individual points - but do so only, when you have to - like in the stem of the boat - as it reduces the overall harmony of the surface. When you are satisfied with the result, mirror the surface to make the full hull and use the 'Create Contours' tool to produce the boat hull lines. The first steps only applies to a sailing boat hull, but you can use the create countours command on any solid. Quote Link to comment
Kaare Baekgaard Posted November 29, 2006 Share Posted November 29, 2006 Oops - forgot: You will have to add longtitutional nurbs points by setting the U degree of the surface to 3-4. Avoid working with more points than you have to. Quote Link to comment
mike m oz Posted December 10, 2006 Share Posted December 10, 2006 Ken - have a look at this movie on the Belgium website. It will give you an idea of how to go about modeling the hull. http://www.designexpress.be/NL/IntB-8.html Quote Link to comment
ludesign Posted September 15, 2007 Share Posted September 15, 2007 Solidworks has a tutorial on their web site that shows the basic concepts of boat hull design. Perhaps you can look at it and get an idea of how it works then translate it to vwks tools. Basically nurb curves and lofting are what you want to do. Although its a little tricky to manipulate them. Once you get the hang of it it goes pretty smoothly. http://www.solidworks.com/pages/products/SolidWorks_2007/SolidWorksOfficePremium2007.html Neither VW or SolidWorks do a particularly good job in actual professional hull fairing. Not that it is anything wrong with these programs. It's just that marine design has special needs. Most professional designers therefore use dedicated programs, as they provide a much better shape control. Things like dynamic cross sectioning is an absolute must to see what you are doing. An example can be seen demonstrated at http://www.touchcad.com/tc3training.html Quote Link to comment
Carl Newton Posted September 19, 2007 Share Posted September 19, 2007 (edited) Hi Ken If you are looking to design and build a boat forget it. I would not even attempt to produce a boat hull with VW. Part of our family business is a boat yard and yacht design and we use the industry standard Maxsurf from Formsys "formsys.com". This is a package like VW were you can purchase various modules for hull design and analyses, however if you are just producing a 3d model for illustrative purposes struggle on, but like you I wish VW had some features for the marine/boat-building industry? What do you think Katie "I know your are watching" Edited September 19, 2007 by Carl Newton Quote Link to comment
Guest Posted September 19, 2007 Share Posted September 19, 2007 I visited a school which uses VW in boat design. It's not impossible. The decision really depends on what is the expected outcome. A relatively straight forward approach to modeling boats, cars, and the likes is to create nurbs curves representing cross sections. A surface can then be created from the nurbs curve network and you end up with a 3D model. This is a pretty standard approach across the board for modeling complex products like boats and vehicles in a variety of CAD & 3D modeling software programs. Quote Link to comment
Carl Newton Posted September 19, 2007 Share Posted September 19, 2007 I have just taken a look at the 2 suggested movies from http://www.designexpress.be/NL/IntB-8.html and http://www.solidworks.com/pages/successes/Success_Stories.html - click Demos. You will have to sign in to view the Demo movies but they are quite good. It would be nice if VW could produce a couple training movies in English to show haw to produce a couple of quality hull designs i.e. a displacement hull, and a semi displacement hull with chimes fitted out with bulkheads, floors and fittings etc. Quote Link to comment
