After talking with Technical Suport it appears that there is no way to set the margins on the borders before generating the borders on all the sheets with the Create Standard Viewports command. I would like to have a 1.5" margin on the left and a half inch margin everywhere else. This works with the binding of a standard set of architectural documents and I could really use this functionality. It appears that one needs to adjust all the margins individually on a sheet by sheet basis to get this 1.5" margin on the left side. Highly tedious. Is there anyway that the next release of Vectorworks could allow you to adjust the border margins either in the Document Setup command or the Create Standard Viewports command? Or am I missing something?
michaelcobb
Any help is appreciated.
0 answers to this question
