Melshimber Posted November 13, 2006 Share Posted November 13, 2006 Hiya I use the Renderworks with V12.5 and recently the View > Lighting > Set Sun Position file option says the Sun Position Plug in is not found in the plug in folder. I checked my hard disk and the file is in the correct place! Does anyone know why this has happened? ttfn Mike Quote Link to comment
Guest Posted November 13, 2006 Share Posted November 13, 2006 Remove it from the workspace and add it back to the workspace. Are you using a workspace from an older version of VectorWorks? Quote Link to comment
Melshimber Posted November 14, 2006 Author Share Posted November 14, 2006 Thanks, Tried that and it worked okay. I was using a VW 12 workspace because this copy was updated to 12.5 I assume it is one of those weird glitches. Ironically a similar problem was found with the door and window tools after the update. Thanks for the info ttfn Mike Quote Link to comment
Petri Posted November 14, 2006 Share Posted November 14, 2006 By the way, if anyone wants to be able to save & restore sun positions, I have menu commands for this. You only need to name the sun as "sun" (OI, Data, top field). You say "Save Sun position" and are prompted for a filename (eg. location, month, day, time). Later you say "Restore Sun position" and are prompted to open a file. Send a private message with your email if you want them. They are VERY handy! You can do eg. shadow studies very quickly after saving a few positions. (Donations to Red Cross or similar non-religious charity are encouraged as payment. Every penny helps!) Quote Link to comment
