Ed Dunn Posted November 1, 2006 Share Posted November 1, 2006 Hi! I have recently upgraded to 12.5. Almost every time I use a menu item (I assume is run by Vectorscript) such as Creat Joist From Poly or Dimension Exterior Walls, VectorWorks crashes. This is happening more frequently as time goes by. At first, it was just an annoyance. I would restart and the next time it would work. Now it is happening enough that I can't complete this job. I may have to work around by filling polys with duplicated lines, dimension the old fashioned way, etc. Mac G5 2GHZ 1.5GB OS10.4.8 Quote Link to comment
islandmon Posted November 2, 2006 Share Posted November 2, 2006 Take a look at the Console Application Crash Log for VW . The most recent crash log probably holds the clue to resolves this issue for you. Quote Link to comment
