MKingsley Posted November 1, 2006 Share Posted November 1, 2006 Whether Show/Snap Others or Gray/Sanp Others is on, I'm not getting complete snappability to other layers. Some parts of objects on different layers will be snappable while others will not, like door or window centers, for example, are unsnappable. However, this changes after I put the old "Align Layer Views" back into the workspace and use it in conjunction with Satck Layers. I can snap to everything with both enabled. Is this happening to anybody else? Speaking of Stack Layers, when is the fix coming for the Paste function not working with Stack Layers on? The curses in NNA's direction are adding up. Quote Link to comment
P Retondo Posted November 1, 2006 Share Posted November 1, 2006 Michael, this sounds like normal behavior. When your active layer is in top/plan view, and another layer is in top view, you won't be able to snap to the other layer. Commanding "Align Layer Views" corrects that inconsistency, and then you can snap to all visible layers. Quote Link to comment
MKingsley Posted November 2, 2006 Author Share Posted November 2, 2006 Except that the other layers are clearly in top/plan as well. I've been noticing file corruption problems (bad template suspected) and that might be the case here but why would aligning layer views fix that? I was curious to see if others have run into this also. Quote Link to comment
P Retondo Posted November 2, 2006 Share Posted November 2, 2006 Michael, I haven't had that kind of problem. Hard to say what could be causing it. Quote Link to comment
MKingsley Posted November 2, 2006 Author Share Posted November 2, 2006 Thanks anyway, Pete. Quote Link to comment
