newhus Posted October 26, 2006 Share Posted October 26, 2006 (edited) Hi, previous to 12.5, you could change your layer and class visibilites (Active Only, Gray Others etc) with keyboard commands: command-option-3,4,5,6,7 Does this work anymore? It is still listed in the Help File in Keyboard Shortcuts. Anyone else? Edited October 26, 2006 by newhus Quote Link to comment
samb'ham Posted October 26, 2006 Share Posted October 26, 2006 Those shortcuts can still be edited in the Workspace Editor>Menus>View. Your default workspace may have been reset when you upgraded. Quote Link to comment
newhus Posted October 26, 2006 Author Share Posted October 26, 2006 Interesting, the shortcuts were unchanged in the workspace but still did not work. I then changed the trim shortcut tool to "T", and then it seemed as if the workspace was working again - so its just a small glitch, and everything works now. Thanks for the idea! Quote Link to comment
Guest Posted October 26, 2006 Share Posted October 26, 2006 If you are using a custom workspace, you need to update the workspace by removing and adding back in the menus and tools that were changed in 12.5. A list of these are included in the rtf file in the workspaces folder. Quote Link to comment
jbrhwy Posted October 27, 2006 Share Posted October 27, 2006 Katie this is the rtf file in the workspace folder, but where is the list of changed tools? "Macintosh Workspace Changes Since 12.0.0 For 12.5.0 New Features Class Options > Gray/Snap Others Create Bill of Materials Create Parts List Edit Viewport Annotation Edit Viewport Crop Edit Viewport Design Layer Export High Dynamic Range Image (HDRI)... Export PDF Export PDF(Batch)... Export KML(3D Only)... Import SketchUp... Invert Selection Layer Options > Gray/Snap Others Changed Features "Display or Hide Constraints" was renamed to "Show or Hide Constraints". "Stack Layers" has to be removed and re-added to the workspace. Export PDF(Quartz only) is now only in the Classic and Standard workspaces" Quote Link to comment
