I just sent in a bug report about the trim tool, because of a situation where having a line alongside the object to be trimmed interfered with its being trimmed properly to a crossing line.
The trim tool is pretty powerful in certain situations. For example, if you want to cut a portion of a line between two crossing lines, just select the tool and click on the portion of line you want to disappear. But in more complex situations, the algorithm doesn't do the right thing, and writing the code to automate it completely might not be possible - in other words, the program might not be able to reliably "guess" the user's intention.
My suggestion is to add another mode to the tool, similar to the AutoCAD trim command, whereby we first select the object(s) to be trimmed to, then select the tool, then click on the object to be trimmed. As I dimly recall, wasn't this the method required in an earlier version? Anyway, this would give the user complete control over how the command is executed, regardless of the context in relation to other nearby objects.
To simplify the interface, this "cutting object by selection" mode could be activated automatically if any object is selected when the tool is invoked.
P Retondo
4 answers to this question
