Custom Line Styles
Under the "File" pull down menu, you can select "Document Settings", then "Dash Styles". There in the dialogue you can control the lengths of the dashed portions of the lines as well as the length of the spaces between them. This is only for the default line types created for VW. I have never found a way to create my own custom line styles. I hope that helps??
