PeterT Posted October 9, 2006 Share Posted October 9, 2006 I have noticed in both VW 11.5 and 12,5 that the Revision Cloud Tool draws the cloud from the input fields according to how the display units are set. In other words, if you set your drawing's display units to "Decimal", and "1", then choose the cloud tool and , the default billow values of .4 display as 0 as they should. The bug is that if you click O.K., and draw the cloud, it will draw the cloud using the displayed values of 0 rather than the internally stored values of .4. The odd thing is, if you open the Object Info Palette, you can change the billow values to .4 and the cloud will redraw using the correct values of .4, although the Info Palette will still display the values as 0, as it should. Quote Link to comment
