Amy L
Objects from Polyline 12.5
Has anyone else had trouble with crashing when using the "convert objects from polyline" in 12.5? So far, after a dozen attempts, I've yet been able to carry out the task. I repaired permissions and it still happens. Steps:
1. Create series of overlapping rectangles.
2. Select all>Modify>add surface.
3. Change new polygon to walls....Modify>convert>objects from polyline>walls.
4.Crash
Note: Crash also occurs with simple polylines (omitting steps 1 & 2.)
12.5 test run on:
Mac PowerBook Laptop
1.67 Ghz PowerPC G4
2GB DDR2 SDRAM
version 10.4.8
To expand on this, I've also had consistent crashes trying to "convert objects
from polyline" in 12.5 regardless of whether its to property line, revision cloud, space, etc. Went back to 12.0 and doing the same maneuvers, everything is fine. Different computer, different system however.
12.5 test run on:
1.67 Ghz PowerPC G4
2GB DDR2 SDRAM
version 10.4.8
I haven't had this problem and have been using it regularly with various presentations.
If you have a specific file, please send it to tech@nemetschek.net along with a detailed description.
If you are getting a crash, please be specific and include the exact message you receive.
