P Bartoli Posted October 5, 2006 Share Posted October 5, 2006 I'd like to customize some DWG files I import from customers. I'd like to change Classes setups (color, weights) automatically (we use to exchange files quite often). Is it possible in vectorscript? I must add that I'm new to vectorscript, maybe there's already around a script that does that. Quote Link to comment
matto Posted January 2, 2007 Share Posted January 2, 2007 You can use the "Modify layers and classes... " command. the first time you do it, once you have class mapping all organised, there is a save file button that will save the set up. This file can be called every time you import a file from that consultant. Maybe not as automated as you would like but will speed you up a fair bit. Quote Link to comment
