cut & pasting bug?
Pete, the problem relates to 2D information only. 3D information will Paste and Paste in Place okay.
As CipesDesign has indicated if you turn Stack Layers off you can then Paste and Paste in Place without any problems. I have added the Stack Layers menu item to both the Document Context and Object Context Menus so I can switch it on and off quickly.
Changing the Layer 2D information via the OIP works okay so the issue seems to be confined to Paste and Paste in Place. Therefore another option is to have the Offset Duplicates VW Preference turned off - you can then Duplicate what you want to copy to another layer and then 'transfer' it using the OIP.
Edited by mike m oz
