mar schrammeyer Posted October 4, 2006 Share Posted October 4, 2006 after several hours work VW12.5 gets tired and stops pasting from clipboard closing & reopening VW fixes the problem but very anoying any one ? Quote Link to comment
MikeN Posted October 4, 2006 Share Posted October 4, 2006 You bet. This one drives me nuts. Quote Link to comment
P Retondo Posted October 4, 2006 Share Posted October 4, 2006 Sounds like a bug - buffer not cleaned up? Quote Link to comment
CipesDesign Posted October 5, 2006 Share Posted October 5, 2006 (edited) There is a bug: when "stack layers" is active: both paste & paste in place do not work (cutting still works fine). Could it be that you have stack layers on when you try to paste? Edited October 5, 2006 by CipesDesign Quote Link to comment
mike m oz Posted October 5, 2006 Share Posted October 5, 2006 (edited) Pete, the problem relates to 2D information only. 3D information will Paste and Paste in Place okay. As CipesDesign has indicated if you turn Stack Layers off you can then Paste and Paste in Place without any problems. I have added the Stack Layers menu item to both the Document Context and Object Context Menus so I can switch it on and off quickly. Changing the Layer 2D information via the OIP works okay so the issue seems to be confined to Paste and Paste in Place. Therefore another option is to have the Offset Duplicates VW Preference turned off - you can then Duplicate what you want to copy to another layer and then 'transfer' it using the OIP. Edited October 5, 2006 by mike m oz Quote Link to comment
mar schrammeyer Posted October 5, 2006 Author Share Posted October 5, 2006 thanks a lot Quote Link to comment
