carletonc Posted September 26, 2006 Share Posted September 26, 2006 I am a bit old fashioned and prefer to draw details and sections without being in a specific section viewport or elevation view. Thus, the main question I have is, is it possible to take the geometry of say a open web steel joist, drawn from the detailing tool set, and convert that into a 2 dimensional object that I can use in a basic drafting mode? Quote Link to comment
Jonathan Pickup Posted September 26, 2006 Share Posted September 26, 2006 you could change to the view that you want and then use the command: Modify > Convert > Convert to Lines... Quote Link to comment
propstuff Posted September 26, 2006 Share Posted September 26, 2006 Convert to lines turns curves into a bazillion little line segments. :-( Use Cmd K to Convert to Group. This will give you either the original polyline or a Symbol. Cmd K will decompose the symbol into its components. cheers Quote Link to comment
islandmon Posted September 27, 2006 Share Posted September 27, 2006 Most efficient technique: edit > 3D Symbol >Top> place a 2d Rect with center line over the Joist>add 2d Loci>Group > assign Class to components( S-JST-16k3 )>exit. Using this technique you can create a single Hybrid Symbol instance for each Joist Type 8K1,10K1, , etc . Then duplicate >edit 2d & 3d>PIO>resize to required length(s). Fast & efficient ... Quote Link to comment
