I am having a problem with the framing member tool.
I get an error saying "The framing Member Tool could not be selected. Make sure it is in your plugin's folder." I have checked and all three needed files are there. I have tried copying the files across from the machine that isn't having the problem. That didn't fix the problem. I have checked with Julian Carr (Australian VW Distributor and all round good guy and VW guru) and he isn't sure what the problem is at this time. I though Katie or some other guru from Nemetschek might be able to help.
In our office we are running PC's. All using XP Pro SP2. Most have Quicktime 7.0.3 installed. Although mine has QT 7.1.3 installed. I have reinstalled 3 times on my machine and it doesn't seem to fix the problem.
At the moment we have installed the 12.5 update on 3 PC's so far. Two have the problem. One doesn't. The one that doesn't is a newer PC with it's own internal DVD drive. The two older workstations have VW installed from an external Sony DVD drive.
Of the two machines that have the problem one is using Quicktime 7.0.3 and the other 7.1.3. The newer machine has 7.0.3 installed.
I look forward to some fine feedback.
Cheers.
PS When I go into the Workspace Editor, drag the framing tool icon out of my workspace, and try to re-insert it back into my workspace, the framing tool does not show up in any list of the tools. Somewhere along the line, the message isn't getting from the Plugins folder to the application front end. (ie there is a break down in between)
Cheers.
Edited by DiamondShare this post
