A shortcut key to enable interactive scaling mode!
Laurence_R
4 answers to this question
Once you go to the zoom tool (you can use the keyboard shortcut to get there), press the U key on the keyboard. This will toggle thru the first set of modes in the mode bar. Pressing U again will take you to the first mode.
[ works for the 5th mode bar grou
] works for the 6th (I haven't found a tool that has this many modes)
If you take the offset tool for example, you can use the U key to toggle between the first two buttons - first mode set.
The I key will toggle between the 3rd and 4th modes - 2nd mode set
So forth and so on
Some mode sets have more than 2 modes, such as the reshape tool. You can use the mode set key to toggle thru all the different modes in the set or section.
