Laurence_R Posted September 25, 2006 Share Posted September 25, 2006 Is it just me or am I not alone in experiencing the odd Disk I/O error when I try to save files to my server? And then again a "Disk I/O error" when I then try to save to my work to my desktop. This happens a few times before VW eventually lets me save in some sub folder or other. Could it be that both my server and my G5 are both dying at the same time? Also I've had a few unexpected program endings (AKA crashes), in the past week since I've upgraded to 12.5, seems to happen when I'm pasting occasionally from one doc to another. I've got a bog standard iMac G5 2Ghz OS x 10.4.7 VW 12.5 Nice speed increase on 12 though, and at last an offset tool that can be used without using the select tool every move! Quote Link to comment
Guest Posted September 25, 2006 Share Posted September 25, 2006 When was the last time you ran disk utility on the local and on the server? Quote Link to comment
Laurence_R Posted September 27, 2006 Author Share Posted September 27, 2006 Today- Both passed with no errors. A dodgy hub connection might explain the server - but the local HD? Quote Link to comment
Guest Posted September 27, 2006 Share Posted September 27, 2006 Sure, if there's an issue with something going on in the background causing a file not to be able to write or a bad sector on the hard drive. Did you run both verify and then repair? Quote Link to comment
