bryn Posted September 22, 2006 Share Posted September 22, 2006 I use a custom dimension with 0.032 (page inch) filled round markers. The settings are not being saved when the custom dimensions dialog is closed. The markers grow to 0.125 inch or turn into arrows. When the settings dialog is re-opened, the marker has reset to arrows. I also can't change the settings by using the arrows pallet because it won't respond when a dimension is selected. I was able to select all the dimensions on the page, change to a default type and back to the custom dimension, but when the file is re-opened, the markers are huge again. Am I missing another setting somewhere? Creating a new type from scratch does the same thing. bryn VW12.5 OS 10.4.7 G4/800 dual 1.25gb RAM Quote Link to comment
