mjb Posted September 22, 2006 Share Posted September 22, 2006 From what I can tell, the JOIN command can only join 2 lines at once... It would be nice if Vectorworks could allow the user to select more than 2 lines and join them at once. Quote Link to comment
Guest Posted September 22, 2006 Share Posted September 22, 2006 The compose command will combine lines that have end points that meet into one continuous object. If the lines do not meet at the ends points, the connect combine tool allows you to do this quickly. If you are looking to meet several lines to one single object, try the connect/combine tool. With all the lines selected, hold down the alt/cmd key while using the connect/combine tool Quote Link to comment
Jonathan Pickup Posted September 22, 2006 Share Posted September 22, 2006 I rarely use the Join command any more, my weapon of choice is the Connect/Combine tool Quote Link to comment
